请推荐专业听间HIFI声卡 [复制链接]
查看: 2896|回复: 2
请推荐专业听音HIFI声卡(硬件)
支持2声道 DTS 5.1 7.1声道
谢谢
下面是个软卡
foo_dsp_xover
Purpose
foo_dsp_xover is a software digital crossover implementation that I have been working on for a while in my spare time as a hobby. It is a foobar2000 audio player plugin that implements this digital crossover to achieve active multi-amplification.
This software needs to run on a WinXP PC equipped with a multi-channel sound card (e.g. 5.1 or 7.1 surround sound card) feeding the various voices of a multi-amplifier and loudspeaker active configuration set-up.
Example of an active crossover setup
I initially developed this software for both DIY speaker development and music listening. Active amplification has always been my favourite mode for listening to music.
Specifications
Stereo
4 voices or less
Filters algorithm: Butterworth, Bessel, Chebyshev
Filter type: Low Pass, High Pass, Band Pass, Band Stop
Filter Order: 1 to 8
Filter frequencies: 1-22050 Hz
Graphical display of:
Filter response
Playing music spectrum
Multi sampling frequency support.
Gain control per voices
Output dialogue allowing each voice configuration:
Routing
Delay in: seconds, milliseconds, meters, millimetres, inches, 1/100 inches
Summing: stereo, mono, sum to left, sum to right
Phase: normal, reverse
Solo a voice
Mute control per voice
Validation data entry error reporting dialogue for:
Filter
Delay
Automatic recall from previews session of all parameters
Configuration data model validation and automatic reset warning dialogue, to avoid misuse of obsolete data.
Screenshots
Main Screen
System Requirements
PC (even runs on a Celeron 450MHz, 256MB RAM)
Multichannel sound card, such as a 5.1 or 7.1 surround card
WinXP PC (SP2 preferably),
Foobar2000 version 0.9.x
Multi channel amplifier and Speakers
Installation
If required, download and install foobar2000.
Then, download the following foo_dsp_xover pluging zip files:
Extract from the downloaded zip file foo_dsp_xover_dll_X_YYY.zip the file foo_dsp_xover.dll and copy it into the directory: C:\Program Files\foobar2000\components
Only if required (not required with WinXP SP2 for example), extract from the zip file msvcr71_dll_X_YYY.zip (zip file only revisionned for SourceForge FRS, it is always the same content) the file msvcr71.dll into the directory C:\WINDOWS\system32 if not already existing.
Use
Using foobar2000->Preferences->Playback->DSP Manager make sure that the "Crossover" entry is part of the "Active DSPs" list.
To modify the parameters of the crossover:
Highlight: foobar2000->Preferences->Playback->DSP Manager->Active DSP->Crossover
Select: foobar2000->Preferences->Playback->DSP Manager->Configure selected
I advise you to first explore this software with one or a few pair of low cost PC speakers. In fact the re-routing output selectors where meant to facilitate such exploration on a PC only equipped with a single pair of multi-media loudspeaker.
Goals
Where am I going with this software?
In fact, towards a software implementation of a Tact style system, but the poor man version. In fact, foobar2000 has another plugin doing convolution that allows in cascade, upstream of my crossover to implement DRC. And who knows, I could eventually feed the power section of my Panasonic SA-XR45 with the I2S line of my PC sound card, PC that runs the all shebang. Allowing me to get closer to the holly Grail of the Tact full digital audio chain, but for le$$ and also DIY.
I have many other plans in my head and on my hard disk, but I will talk about that later.
Projects
I invite you to send me info on how you use this software: descriptions, picture, diagrams, web link. I will be very happy to discover other people sharing my passion for audio and if you agree I will be sharing these here.
Acknowledgement
A part of this software is inspired by the late Tony Fisher work. This web site is surviving Tony and I have ported some of Tony’s corresponding code into this software. Thank you Mr. Fisher.
Links
The development of this foo_dsp_xover project software lives on  and it is a plugin develloped for foobar2000
DRC is a very sophisticated piece of work that should give people a strong insight on where I think digital audio restitution is aiming towards. Bravissimo Sinior Sbragion!
Channel Divider is what I would describe as an alternate piece of work to what I am doing. You can find more information about it here it uses a different algorithmic approach, that is worth exploring.
ACXO (Acoustic Correction and Crossover) is fully integrated software (including the media player) for a digital audio processing system running under Windows.
BruteFIR is a specialised processing engine dedicated to the Linux platform that handles high performance FIR filter runtime implementation.  One needs to have sets of FIR coefficients calculated off-line by other means to use BruteFIR.  This software is developed by Anders Torger and is a very interesting and sophisticated piece of open source software.
Mr. Linkwitz is an inspiring engineer; I am please to share the link to his site, because of the indisputable multi-amplification (read: active crossover) approach to the engineering problem of audio restitution he follows, among many other innovative concepts he brings to the audio domain.
About us
My name is François Bourdon, I live in Verchères, Québec, Canada and I have a personal web site that I should update eventually.
I confess that I have been reluctant for a while to release this software that I felt too immature for public release. But a colleague strongly recommended to me, to let this software live on the public place and in the pure spirit of open source software, to let it grow in the community, benefiting from the community voluntary help in what ever forms that comes.  That help could (is): simply using it, talking about it, writing about it, testing it, reporting bugs in it, reporting to me about it’s use, suggesting new feature for it, coding it, criticizing it (to me especially), using alternative to it and even competing against it…
That motivating colleague is Fabrice Crestois, Merci! Fabrice.
Warning
I am not responsible for the consequences of using this software, especially on tweeters. Use at your own risk
This is a beta version, be indulgent in your expectations of this free and open source software.
This is an open source project, yet my authorization for use in a commercial project is required.
Otherwise go ahead and have fun right away!
http://xover.sourceforge.net/[upload=jpg]Upload/20067142255685588.jpg[/upload]
http://www.acoustic-reality.com/[upload=jpg]Upload/20067142313325542.jpg[/upload]
安桥SE-150PCI和 SE-90卡整体都使用了镀金接口,并且抛弃了传统的3.5寸接口,转而使用了更加出色的莲花接口作为数据线。
    这款声卡第一眼看上去就好像是为音乐而设计的。抛弃了全铝壳电容,而使用传统的电解电容。以前我们经常评价声卡的好坏要看声卡的制造成本,其实这个是片面的,出色的电解电容的声音更加有特色。很多方面都是铝壳电容所不能做到的。同时使用传统电容还有一个好处就是可以自己动手改造,而铝壳电容则改造的可能性要小了很多。同时这个声卡还在输出部分作了一个金属的屏蔽,这样的设计有利于使声音更加纯净的输出。
