测试了比较好匹配是丹麦皇冠超级麦林! [复制链接]
查看: 3692|回复: 1
测试了比较好匹配是丹麦皇冠超级麦林!
整理一下罗大哥的搭配测试资料给大家参考:
搭配一、传神M1+丹麦皇冠超级麦林12 (评价★★★★★
[upload=jpg]Upload/20073270155375366.jpg[/upload]
Magnum12
2 Way ported
7" Scan Speak/Avance Coated kevlar
3/4" Scan Speak/Avance
54/20000Hz
80hm
86dB
33x19x28cm 13"x7.5"x11"
8.2kg 18.1 lbs
30-200W
详细资料:
http://www.avance.com.cn/product-series.asp?id=1
搭配二、传神M1+丹拿轮廓S3.4  (评价★★★★☆)
[upload=jpg]Upload/2007327183045686.jpg[/upload]
技术规格
灵敏度 (2.83 V/ 1 m)
86 dB
IEC长时间承载功率  270 W
标称阻抗 4 Ohm
重量 33,3 kg
体积
(W x H x L in mm) 357 x 1226 x 366
详细资料:
http://www.dynaudio.cn/html/contour34.htm#
搭配三、传神M1+B&W804 (评价★★★☆☆)
[upload=jpg]Upload/2007327194878877.jpg[/upload]
技术规格
Description 3-way vented-box system
Dimensions Height: 1020mm (40.2 in) (not including feet)
Width: 238mm (9.4 in)
Depth: 351mm (13.8 in)
Net Weight 28kg (62 lb)
Freq. Response 38Hz - 22kHz ±3dB on reference axis
Freq. Range -6dB at 30Hz and 50kHz
Sensitivity 90dB spl (2.83V, 1m)
Normal Impedance 8 ohms (minimum 3.0 ohms)
Power Handling 50W - 200W into 8 ohms on unclipped programme
Drive Units Unit 1: 1x 25mm (1 in) aluminium dome high-frequency
Unit 2: 1x 150mm (6 in) woven Kevlar® cone FST midrange
Unit 3: 2x 165mm (6.5 in) Rohacell® cone bass
Finish Cabinet: Real wood veneers of Cherrywood, Rosenut or Black Ash
Grille: Black cloth
Dispersion Description: Within 2dB of reference response
Horizontal: over 60º arc
Vertical: over 10º arc
Harmonic Distortion 2nd and 3rd harmonics (90dB, 1m)
<1% 90Hz - 22kHz
<0.5% 120Hz -20kHz
Crossover Frequency 350Hz, 4kHz
Max. Recommended Cable Impedance 0.1 ohms
详细资料:
http://www.bwspeakers.com/index.cfm/fuseaction/products.models/label/Model%20804S
搭配四、传神M1+威卓(评价★★☆☆☆)
详细资料:
http://www1.21hifi.com/revhifi/20020418/012.htm
最后编辑阿胆
