意大利 Synthesis 超靓声迷你胆合并功敌 "Ninis" [复制链接]
查看: 7660|回复: 25
[upload=jpg]Upload/200491516385549799.jpg[/upload]
[upload=jpg]Upload/200491516391981362.jpg[/upload]
[upload=jpg]Upload/200491516393597743.jpg[/upload]
10K 内:
http://www.audioxtension.com/rev/synthesis/synthesis.htm
不是我的,可以代订,因代理就在我楼下,但他们只做直销,加上现在他们已在做特价,所以我也拿不到批发价,据闻汕头折实后也要卖一万三千多!
如果代订除汇价外加收中港运费及 3% 手续费,但因只是代订,一定要先付款啊!
原配音箱亦可代订,些箱异常好推呢!
Synthesis Nimis
Product: Synthesis Nimis tube integrated amp
Manufacturer: Synthesis - Italy
Approx. price: 800 Euro/ 850 US $
Synthesis is an Italian Company that makes tube amplifiers, both integrateds and preamp/amp combos, with a great attention to the quality of the finish and crafsmanship [the picture speaks so much louder than words... :-) ]
The Nimis is the smaller integrated made by Synthesis and it is one of the most affordable tube amps available in the market (here in Italy, at least).
Looks and craftsmanship
This amp is a beauty: smallish (32 x 22 x 12 cm), carefully finished and crafted, this shiny integrated does have a very high WAF factor!
The output transformers have a polished chrome armour with a golden Synthesis logo on top...more or less like vintage Harley motorbikes :-)
The rear view is very nice too: the gold plated input connectors, placed on the top cover allow your precious interconnect cables to be "in vista" instead of being hidden as usual :-)
In the rear panel we also find the on/off switch and the IEC mains socket, plus four gold plated output posts.
On the front panel, besides the metal grid that avoids unwanted and potentially dangerous "contacts" with the hot power tubes, we can find double volume controls and double input selectors (YES!!!) since the amplifier is entirely DUAL mono.
The whole package is surrounded by a real red wood finish, so carefully polished that anything else near the Nimis will look awkward and definitely cheap...
I must admit this is one of the coolest looking HiFi components I've ever seen (pictures are never enough...).
Some tech spec
The amp uses a pair of 12AU7 tubes and a pair of 6BQ5 (in pentode configuration) for the power stages which deliver 15 watts @ 6 Ohm.
3 line inputs + 1 one tape loop is all what you get in the inputs department. While very small the Nimis is pretty heavy, weighing in an impressive 10 Kgs (23 lbs).
On the road...
The Nimis was not designed to remain hidden somewhere into an ugly black anonymous HiFi rack: place it so that everyone can see it...on top of an elegant rack, for example, so that it doesn't overheat.
The double input selector (one per channel) and the double volume pot, though very "audiophile", are pretty uncomfy to use...as is the on/off switch placed on the rear panel, especially if you listen to the amp without the grid....ouch!
The loudspeakers output post are very easy to use and offer a good "grip" to the fingers.
Listening test
The Nimis has started to show it's personality just after 50 hours of break-in...before it's sound was confused and pretty unstable (changing day by day).
First of all let me remind you we're talking of a cheap tube integrated amp here, maybe one of the cheapest around (at least, as I said, here in Italy), especially considering the very high quality of the finish.
The tonal balance is on the soft and warm side though the highs slightly prevail over the mid range, so that the sound sometimes appear a bit on the thin side.
The mids are "fluid" and "liquid" but also light and hence the female voices sound thin and so the violins and cymbals. The same applies to male voices and choirs.
You can't find full-bodied and hyper-detailed sound in cheap amplifiers and so this Nimis makes no exception to this rule, sounding smooth, never particularly introspective or "solid".
The Nimis is never dynamically explosive also, since it prefers to sound "fluid" and quite relaxing. The Music flows through it like water in a large and quiet river.
Either you love or hate it: if you fall in love with it you'll be able to forgive some indecision on the mid-bass, especially when it can't properly control large woofers.
You will also be able to enjoy a small and coherent soundstage where contours appear "blurred" and extra-smooth...no hyper-definition allowed here, thanks.
It's driving ability is adequate with standard easy loudspeakers into mid-sized listening rooms.
Complaints
Well, it is clear that this amp does have some limitation though I think it should be thought as a small, smooth tube amp, born to play Music into a relaxed environment, hence common audiophile "figures" need not to apply here. Either you love or hate it.
For example, I've hated the double controls (both input selector and volume) since they make adjiusting the correct balance between left and right channel a real pain in the neck.
Some advice
Choose carefully your loudspeakers: they should be an eaaaasy load, with a warm and solid mid range, a controlled and fast bass and a detailed high range.
As for cables: for example, a strongly recommended choice would be a pair of our TNT FFRC's, which have a very good and clean mid range.
Also, a good match would be the Marantz CD 67 CD player, for example.
Conclusions
Are you searching for a cool-looking smooth-sounding cheap tube integrated amp? Look no further, here's the Synthesis Nimis. Probably not the ultimate in detail, dynamics and "drive" but certainly a fine and relaxing Music perfomer, with the "plus" of being a tube amp...
If these "qualities" don't suit your needs...look elsewhere!
A warm thank you to Luigi Lorenzon of Synthesis - Art in Music for having sent us the Nimis for reviewing.
© Copyright 1999 Stefano Monteferri - http://www.tnt-audio.com
How to print this article
最后编辑leslie
基本上和连键的中文评沦所说差不多,也是可以用「惊喜」两字来做总结,个人感觉是纯真自然,而且功放及原配音箱各自单独搭配其他品牌亦很容易,兼容性十分之强,这和有着非常出色的音色平衡度有关。
如果听音空间小於 30 方,配一部¥5K 内的 CD,加上线材脚架等,在总价三万水平不难调配出一套堪称五万元内绝强组合。
单论功放本身,我可以简单说一句,国产品牌们,自强一点吧!
几钱啊
威马兄说说听感???
起碼過10K
约几钱一台呀?
如果价钱都靓就好了
[upload=jpg]Upload/200491517363393509.jpg[/upload]
不贵哦:)
(All the below is with the non-stock Sovek tubes)
Tonality 80
Sub-bass (10 Hz - 60 Hz) 70
Mid-bass (60 Hz - 200 Hz) 80
Midrange (200 Hz - 3,000 Hz) 80
High-frequencies (3,000 Hz on up) 75
Attack 75
Decay 75
Inner Resolution 85
Soundscape width front 80
Soundscape width rear 70
Soundscape depth behind speakers 75
Soundscape extension into the room 75
Imaging 80
Fit and Finish 95
Self Noise 100
Value for the Money 85
Specifications
Inputs: 4 line
Outputs: 1 record
Input impedance: 100 Kohm
Output impedance: 6 ohm
Frequency response: 20 Hz - 20 KHz
Power output: 15 Watts 6 ohm
Configuration: Pentode
Tube compliment: 2 x 12AX7
                          4 x 6BQ5
Power consumption: 100 Watts
Dimensions: (w/d/h) 32O x 220 x 120 mm
Weight: 10 Kg
http://www.enjoythemusic.com/magazine/equipment/0700/nimis.htm
最后编辑leslie
