新入手天朗TANNOY ST-50超高音喇叭全评测--对比ST200 [复制链接]
查看: 7171|回复: 3
在研究了日本STEREO SOUND杂志对天朗三款超高音的评价,再结合我在朋友家听过的ST200超高音的实际表现后,我选择了价格适中的ST50超高音。接下来,我会和大家探讨这款ST-50超高音。在此提醒用天朗大喇叭的朋友,超高音必须加,否则,以天朗喇叭的设计而言,不加超高音的话,天朗喇叭对与超高频信息的表现是有先天不足的,特别是对比B&W,FOCAL等高音出色的喇叭而言,这点已经得到天朗官方说明。我会在下文逐步与大家分析。
下面,我们先来看日本STEREO SOUND 杂志对与ST-50,ST-100,ST-200的评论。
首先,ST200与ST100售价均为24万日元。他们的用料完全相同,都采用了整块木头挖空内部制成,具有完美的制作工艺。都采用了镀金的钛振膜,与钕磁铁。
ST100,ST200这两个型号的区别,仅仅在于分频点的设计不同,ST200拥有89dB,90.5dB,92dB,93.5dB,95dB的灵敏度,这些灵敏度适用于天朗的喇叭。而ST100对应的5阶段灵敏度为87dB,89dB,91dB,93.5dB,95dB,适用于各种品牌的各种型号的喇叭。
而ST50超高音,售价仅为14万日元。之所以能够便宜10万日元,在于其外壳采用了树脂制成,而且,并非整块切削,而是上下两片组合成球形。此外,灵敏度也从ST200与ST100的5档,简化为3档,分别是85dB、89dB、93dB、而且,我们从官方说明书上可以发现,还有一个重大不同,在于,其内部的连接线没有像ST200,ST1000那样采用纯银线。
在天朗官方网站(http://www.tannoy.com/),关于超高音介绍原文如下:
Always an innovator where quality sound reproduction is concerned, Tannoy has continued this tradition by being at the forefront of the
development of WideBand™ technology. All Prestige models are compatible with Tannoy’s SuperTweeter™ designs, providing the
opportunity to extend high-frequency response to above 50 kHz, thereby providing all of the bandwidth required for today’s wide bandwidth
digital recording formats.
In fact the SuperTweeter™ only starts working at a point that is close to what is generally considered the limit of the audible frequency
band for most adults. The Dual Concentric™ in the main loudspeaker, still working to its full frequency specifications, continues to provide
the heart of the musical information as a coherent point source. However, the extreme high frequencies are then resolved by the SuperTweeter™
to provide incredible, wide bandwidth detail and enlivening the performance by increasing the tonal accuracy of individual instruments
for more natural and true to life music reproduction.
The Tannoy SuperTweeter™ extends the high frequency capability of the complete
loudspeaker system out to beyond 50kHz. This in turn corrects the time
and phase response at the upper end of audibility to deliver enhanced
accuracy and spaciousness, improved clarity within the essential
mid band area and even an enhancement of the definition and impact of low frequencies.
Benefits are heard clearly with any source material, regardless of bandwidth, therefore ensuring
that a Tannoy SuperTweeter™ is an essential accessory for any model in the Prestige range.
  ST200
The oiled American Walnut casing of the ST200 is specifically designed to
partner the Prestige range of Dual Concentric™ loudspeaker designs. From Stirling
right through to the iconic Westminster Royal, this SuperTweeter has adjustment
optimisation, appearance, style, construction and performance to greatly improve the
overall listening experience.
Supplied with detailed crossover set up instructions and a calibrated location gauge,
to allow accurate front to back positioning for all Prestige loudspeaker designs past
and present, this simple installation delivers a substantial acoustical enhancement.
The wide range of adjustments provided for crossover frequency and level ensure that
the ST200 is equally suited to the earlier classic Tannoy designs, including older
Prestige, HPD, Monitor Gold or Monitor Silver models.
ST100
The ST100 is constructed with the same Performance Platform™ as the ST200, but this time with a solid black ash
enclosure. This model is provided with a different range of crossover and frequency control settings designed to offer wider
flexibility to acoustically match all types of speakers, regardless of manufacturer. In addition the ST100 is optimised for
use with older Tannoy Dual Concentric™ models, many going back over 45 years to the original
15” Monitor Red derivatives.
ST50
Constructed from solid aluminium die-castings coated with a soft feel, non-reflecting finish, this innovative
modern design is designed to visually blend with all types of speakers. With a wide range of adjustment settings
designed to integrate with the product with which it is partnered, the ST50 is a spectacularly instant acoustic upgrade.
Arguably one of the most cost effective performance enhancements you can apply to your audio system; one that
completes the musical picture with an increased immediacy, airiness and impact, making music more true to life.
我为大家翻译以上天朗官方对ST系列超高音的介绍:
所有的天朗音箱均能通过ST系列超高音,使得高频响应超过50千赫兹,从而满足现代宽频数字录音格式的需要
实际上,ST系列超高音的起使工作点,是在大多数成年人能够听到的频段的极限点。此时,天朗同轴音箱仍然以同轴方式发出感人的音乐。而ST系列超高音单元,负责极高频段的再现,提供不可思议的宽频段细节,使得音乐更有生命力,每件乐器的泛音细节更准确,音乐更加自然与真实。
由于ST系列超高音能延伸至超过50千赫兹,因此他使得最高频段的时间与相位的反应更加准确,从而强化了准确度与空间感,提高了中频段通透度,甚至,加强了低频的凝聚度与冲击力。
ST200的特点:用美国油胡桃木制作外壳的ST200,为配合天朗贵族系列的外观而设计,从Stirling(斯大林),一直到Westminster Royal(皇家西敏寺),能够大大提高总体声音。由于设计了多档调节,ST200能够在老款天朗音箱上使用,包括老贵族系列,HPD系列,金参考,银参考等。
ST100的特点:ST100ST200结构相同,但是,外观颜色采用黑灰色。灵敏度调节范围比ST200广,使得ST100适合于各种类型,各种生厂商的喇叭。不仅如此,ST100对应各种天朗的老款喇叭,可以追溯到45年前的15寸红监听。
ST50的特点:使用铝制腔体,外覆手感细腻的树脂制作而成,适用于各种品牌的各种喇叭。使用ST50立刻能感到声音的升级。这是最经济的升级音响系统的方法,使得音乐画面更加直观,充满空气感与冲击力,是音乐更逼真。
我们来比较一下官方说明书上ST50ST200(ST100)的特点,看看有何异同。
ST50说明书
第一点:采用高硬度钛振膜减小振膜分割震动影响,增加频响延伸。
第二点:采用铜包铝线制作音圈,能承受高功率。
第三点:钕磁铁增加频率响应减小音圈涡流损失。
第四点:提供磁力驱动系统接地,避免电磁干扰引起的信号干扰与信号损失。
第五点:镀金端子提供高效信号传输。
第六点:分频器采用优质电感元件。
第七点:采用不导电电阻避免普通绕线带来的损失。特别为高频传输而选择的优质聚丙烯薄膜电容。
ST200说明书
注意,比起ST50,ST200的第五点特点很重要,就是采用高纯度99.999%的纯银内部接线,用四氟乙烯(PTFE)作绝缘包覆材料。其他基本一致!
我来简单翻译ST50的说明书
ST50介绍
ST50设计的背景是为了应对现代录音与音响材料的极高频延伸。音乐信息包含有弱小的信号信息,这些信息超出了人耳的聆听范围。但是,为了使音乐更加准确地再生,我们认为,有必要精确还原这种信号。
ST50适应于各种喇叭。你可以根据你使用的喇叭的频率选择相应的频率与灵敏度。
关于煲机
与所有喇叭一样(请使用喇叭或耳机的朋友注意),为了达到最佳状态,释放材料应力,请以较大音量播放20小时。(注意,我原来的B&W805S的说明书里的要求也是20小时。)
那么,ST50与天朗ARDEN的组合究竟有何效果呢?
答案是肯定的正面作用。高音表现姑且不谈,仅低频部分,就真的如天朗官方网站所说,加了超高音反而低频的速度,凝聚度,瞬态都显而易闻地大幅度提高,而高频,更是通透无比,我仿佛在听单拿音箱的高音。最关键的是,ARDEN的整体线条都大幅度凝聚,而洗练!表现交响乐,很明显各种乐器间的分离度得到超级强化,背景展现出惊人的空气感与通透度!整套系统仿佛小宇宙爆发!展现出惊人的HIFI性,而原本的音乐性,仍然得到很好的保留。我再次强烈推荐是同天朗音箱的朋友入超高音。在拿下ST50后,我可以感觉到一下子失去了高透明度与高结像度!可以说,我已经离不开ST50,而ST50对于系统整体有相当高的正面作用。
加装了ST50后,我试验了分别用AUDIO NOTE银线与铜线进行连接。银线明显高频更加细腻,延伸更加强,但是,实际听感反而不如铜线,用铜线时,ST50完全融入系统,仿佛超高音根本不存在。我分析原因很可能因为我的主喇叭是用铜线,因此,超高音用银线有明显的风格冲突。我进而猜测,如果喇叭线也换成银线,而且要声音走向与超高音一致的同厂银线,可能会比较搭,这个以后有机会再试验。
接下来,我带着ST50,来到我的朋友王先生家里,与他的ST200进行详细对比。
ST200在与ST50的对比中,显示出让王先生的天朗15寸GRF TWW更加透明的空气感,而且,线条也收的更加紧密,素质在ST50之上是一耳朵的事情。展现出更多银线的声音特质,这与ST200的内部接线全部采用银线绝对有关。可以说,在GRF音箱上,ST200更加优秀。当然,这于先天设计也有关,王先生平时将ST2000放在灵敏度95这档上,而我的ST50,最高只支持到93的灵敏度,先天最高灵敏度就不如ST200。但是,考虑到差价达到10万日元,我认为,ST50的性价比与经济性事不言而喻的。
在ST200的说明书里(见下图)附送了一张45年来所有天朗音箱的超高音摆放距音箱边缘的距离,这是考虑到与音箱同轴单元的发声点对齐的方式(可以参考下面的图)
最后,我强烈推荐在使用天朗同轴音箱的朋友,如果希望声音通透度变高,高频延伸细腻无尽,低频变快速而凝聚,音乐细节提高,那么,完全可以考虑加装ST50,ST100,ST200超高音,加了后,你会发现天朗喇叭的全面性提升!让你再也摘不下来!
(全文完)
由于168传图仅限十张,更多详细大图,感兴趣的朋友可以直接看我的博文:http://blog.sina.com.cn/s/blog_40f078a90100k4w0.html
最后编辑sega88 最后编辑于 2010-07-04 12:36:57
看中这个高音很久了
原帖由 xiaowu0750 于 2010-7-4 13:05:00 发表
看中这个高音很久了
值得购买
jpg(2010/7/4 18:30:02 上传)
玩天朗感觉要加超高,要先看看自己的系统是否有问题。尤其是功放。
