请问:在什么情况下需要使用相位转换(180度)? [复制链接]
查看: 2060|回复: 2
刚入手一部 前卫 SF D1 MK- II 解码,在面板有个相位开关,可以选择0度或180度,听起来我觉得好像分别不大,想请了解同学告之一二,谢谢!
吹水公话斋:认真去玩,随便去听!!
它的原文是:
-Phase Control Switch - This toggle switch allows the user
to invert the system phasing easily and safely. When the switch
is in the 0° position the SFD-1 MKII will put out a normal or
non-inverted signal in relation to the signal being received from
the source. When the switch is in the 180° position the SFD-1
MKII will put out an inverted version of the signal as compared
to that being received from the source. This feature offers a
convenient method of correcting source material which was
recorded “out of absolute phase” or to counteract for a component
in your system such as a preamplifier, power amplifier or
signal connection which inverts phase.
但我看得不太明白!!
吹水公话斋:认真去玩,随便去听!!
一般美标插头相位应该固定的了,如是2插可能需要转换。
《常见疾病治病解说》最实用的家庭医生
http://daniel115.taobao.com
