返回列表 12345678» / 21
废柴大叔 ※※※ 公开箱体设计第二季 ※※※ Gracy Baby [复制链接]
查看: 84270|回复: 206
H1224-08 L18RNX/P
L18RNX/P is a 6,5” High Fidelity woofer with an injection moulded metal chassis, intended for bass reflex and transmission line designs.
Stiff, yet light aluminum cone and low loss rubber surround show no sign of the familiar 500-1500 Hz cone edge resonance and distortion assosiated with soft cones.
Large magnet system gives good transient response, and the bumped back plate together with the very long, and light weight copper clad aluminum voice coil allow for extreme coil excursion with low distortion.
Extremely stiff and stable injection moulded metal basket, keeps the critical components in perfect alignment.
Large windows in the basket both above and below the spider reduce sound reflection, air flow noise and cavity resonance to a minimum.
Frequency response
The frequency responses above show measured free field sound pressure in 0, 30, and 60 degrees angle using a 12L closed box. Input 2.83 Vrms, microphone distance 0.5m, normalized to SPL 1m.The dotted line is a calculated response in infinite baffle based on the parameters given for this specific driver. The impedance is measured in free air without baffle using a 2V sine signal.
Specifications
*IEC 268-5 SEAS reserves the right to change technical data.
Dimensions
本主题由 版主 eric 于 2014/6/28 21:22:15 执行 设置精华/取消 操作
3L-Audio Studio, established since 1993, has been dedicated to Hi-Fi audio R&D for over 20 years.
沙发,这喇叭应该算是标准的5寸吧,为书架箱准备的吗?
原计划
原帖由 3l 于 2014-3-14 16:37:00 发表
预告:第二季,两分频三路,双中低音单元,两个中低音单元设计不同谐振频率的独立声腔,两声腔设置不同的反射管谐振频率......
温哥华的朋友BID了套H1224 + H1212,改计划,继续书架。
回复 2# WLCCWLC 的帖子
坊间应该算6.5"吧
H1212-06 27TBFC/G
27TBFC/G is a High Definition metal dome tweeter with a wide, soft polymer surround and a rear chamber.
Aluminium/magnesium alloy diaphragm with pistonic behaviour throughout the audible frequency range, resulting in a good dispersion also above 10kHz.
A Hexagrid protects the diaphragm, and supports a phase plate which compensates for a slight axial roll off towards 20 kHz.
Sonomax surround for low resonance and excellent mechanical linearity.
Voice coil windings immersed in magnetic fluid increase short term power handling capacity and reduce the compression at high power levels.
Stiff and stable rear chamber with optimal acoustic damping allows the tweeter to be used with moderately low crossover frequencies.
Precision moulded chassis from glass fibre reinforced plastic, and its front design offers optimum radiation conditions.
Frequency response
Specifications
*IEC 268-5, via High Pass Butterworth Filter 2500Hz 12 dB/oct. SEAS reserves the right to change technical data.
Dimensions
今次妖都、温哥华同时行动,温哥华那边玩DIY,藕这边按标准产品出样。
妖都会用另一高音单元H1189-06 27TDFC
27TDFC is a High Definition precoated fabric dome tweeter with a wide, soft
Sonotex precoated fabric diaphragm with high consistency and excellent stability
against variations in air humidity.
The chassis is precision moulded from glass fibre reinforced plastic, and its front
Frequency response
The frequency responses above show measured free field sound pressure in 0, 30, and 60 degrees, mounted in a 0.6m by 0.8m baffle. Input 2.83 Vrms, microphone distance 0.5m, normalized to SPL 1m. The impedance is measured without baffle using a 2V sine signal.
Specifications
Dimensions
已开声的,搭手头现有的老古董H519慢火炖。
这箱体的反射管频率A1 flat, 反射管频率与箱体频率为一大三度音程。
接下来要做的箱体的反射管频率G1,反射管频率与箱体频率同样为一大三度音程。
用这鸟合并,声音相当银荡鸟。
HIFI何价?这台鸟合并的价钱,1999厂方定价 RMB 1800.
从巴洛克到摇滚、重金一窝端,如何?
1800?不奇怪,音乐版的老KEN,当年用哈曼的前后级推他的FOCAL土炮,后来换上了珠海出的国货,也就这个价格,一直听到现在。每次他弄其它的货回来折腾的时候,俺总觉得听得最舒服的还是那台......
