版主 [复制链接]
查看: 2828|回复: 5
是否听过美国HERRON AUDIO VTSP-1A 前级,声音特点如何,适合搭配什么后级.
胆前?后级预算??
[upload=jpg]uploadImages/2003741428030513.jpg[/upload]
[upload=jpg]uploadImages/20037414145322780.jpg[/upload]
Design Considerations
Perfect tracking volume 142-step control system with unprecedented precision and dynamic range
Infinite resolution indirect signal path balance control
All-tube design operated conservatively for long life
Relay input switching eliminates switching distortion
Star grounding for low interference susceptibility and clean signal path
Zero feedback - no feedback loops in the audio circuitry
Super-low noise
High input signal capacity without overload; see technical specifications
Gold plated TIFF RCA and ground connectors
Hand-picked components for accurate response and consistent unit-to-unit quality
Automatic muting at startup and shutdown
72,000 µF of power supply energy storage capacitance
4 levels of high voltage regulation
Regulated soft-start DC filament supply
Regulated tube bias supply
Toroidal power transformer
Rugged 0.10" thick aluminum chassis with 0.25" thick heavily anodized faceplate
Reversing power line (AC) polarity switch for minimizing line-to-chassis reactive currents and noise pickup
Controlled warm-up of tube filaments and high voltage for extended tube life
Low plate operating currents for extended tube life and cool operation
Front panel indicators for power, filament voltage, and output/mute/monaural
Each unit is given an extensive burn-in, including rigorous bench and listening tests
Specifications
Tube complement
4 x 6922
Frequency response
1 Hz to beyond 100 kHz, 20 Hz to 20 kHz ±0.1 dB (volume control at 9 o'clock)
Volume Control
142-position electronic stepped attenuator
Volume Tracking
Maximum differential: ±0.1 dB channel to channel
Gain
14 dB
Output impedance
100 Ohms nominal at 1 kHz
Input impedance
100,000 ohms
Power supply
72,000 µF of energy storage
Regulated soft start DC filament supply
Power requirements
U.S.: 120 VAC 60 Hz, 30 VA, Fuse 1/2 amp 250 volt slow blow
Export: 230 VAC 50/60 Hz, 30 VA, Fuse 1/4 amp 250 volt slow blow
Input capacity
18 Volts RMS
Overall dimensions
19" wide x 3.5" high x 10" deep
Warranty
5 years, parts and labor
Tubes: 90 days
Suggested Retail
$3,995.00
[upload=jpg]uploadImages/20037414271786412.jpg[/upload][upload=jpg]uploadImages/20037414272645114.jpg[/upload]
以Herron VTSP-1A/Audio Space AS-300B胆机组合推动TAD TSM-300喇叭播放CD时已取得通透无匹的三极音色和气势非凡的爆棚力道,用Air Tight替代Audio Space之后,我要承认两者的音色、音乐感和力水其实相差不大,但到我改用黑胶唱盘播放过多张天碟录音之后,两部机的声底分别就比较明显,毫无疑问Air Tight举止比较优雅,特别是播放弦乐时,弦乐较具轿贵气息,另一方面,Audio Space个性比较豪迈,播放爵士更为开放生猛,力水方面,两者都肯定是[大力士](以单端输出8瓦的胆机而言),推动TAD固然爆到七彩,配搭市场上大部分扬声器亦不成问题。
载自《发烧音响》
