blue circle BC8 - Mono Block Power Amplifier [复制链接]
查看: 2178|回复: 5
[upload=jpg]uploadImages/20041514182315157.jpg[/upload][upload=jpg]uploadImages/20041514183016618.jpg[/upload]
Technical Information
225 watts per channel into 8 ohms, over 1600 watts into 1 ohm
High bias Class AB
6 ultra high power output devices each capable of handling over 392 watts into 8 ohms
HEXFRED ultra fast soft recovery rectifier diodes
Power supply
- simple(it's Blue Circle) yet effective, yielding clear transparent music
- 120,000 uF capacitance per channel
- 2,600 watt power transformer
Thermal & DC offset protection
Blue Circle soft-start circuit to eliminate "turn on thump"
True balanced floating circuit topology
DC coupled from input to output
All internal wiring in the signal path is Cardas®
Heatsink
- military grade "PIN FIN" custom designed for Blue Circle
- 60 % more efficient than conventional heatsinks
Chassis material: military grade non-magnetic stainless steel
Balanced input: XLR (single-ended adapters are supplied)
Outputs: 2 pairs of Cardas® binding posts for shotgun bi-wiring
Dimensions: 9.5" (241mm) x 9.5" (241mm) x 22" (559mm)
Weight: 71 lbs each without packaging
[upload=jpg]uploadImages/2004151419547545.jpg[/upload]
MKII version MSRP: 7295.00
Are you experiencing true concert hall dynamics in your listening room? When you listen to intimate music are you feeling the subtle nuances and emotion that the musicians have imparted to the performance? If you answered no to either of these questions then your system is not providing you with all the information that is contained in your source material.
The solution is the BC8.
Recorded music has the potential to move the listener emotionally but most power amplifiers fall short in this respect. They either overpower you with muscle or wimp out when you need them the most. The BC8 simply presents you with what the artists and the recording engineer provided on the source material. If the music is dynamic then you will hear dynamics! If the music is soft and gentle then you will experience all the subtlety and harmonic balance of the performance.
If you want to get excited about music again then this is the amplifier for you.
最后编辑leslie
BC32 Multichannel Amplifier
        MSRP: 5 ch  $2650.00 USD
        6 ch  $3050.00 USD
The BC32 Multichannel Amplifier represents Blue Circle's approach to home theatre sound. Quite simply that means we approached the design criteria of the BC32 with the same standard we have for all our products, no compromise in sound and handcrafted. The BC32 represents a combination of our passion for music and sound engineering principals. We have incorporated some of the superior designs of the well regarded 20 Series, as well as some new and innovative ideas. The BC32 is designed to run cool and is very reliable and stable even under the most demanding loads, with features that make it easy to install.
With it's incredible dynamics and musicality, this new power amplifier will bring life into your system. You will feel the bass as it was meant to be felt. The passion and emotion of the voices along with the ambience of the concert hall are captured and faithfully reproduced. Blue Circle has brought a new dimension to the Movie enthusiast, musicality.
Handcrafted to Blue Circle standards, the BC32 is truly one of the premier multichannel amplifiers and should be considered for any serious home theater installation.
Options:
..12V trigger
..Available from 2 to 6 channel.
..Bridgeable to 300W into 4 ohms(factory set).
..Balanced XLR inputs available.
Technical specifications
Power output: 130 watts per channel into 8 ohms, 5 or 6 channels
Power requirement: 120 VAC 50/60hz, 750 watts max; also available for 100, 200, or 240 VAC
Dimensions (w x h x d): 17" x 7.25" x 16" | 432 mm x 184 mm x 407 mm
Weight (without packaging): 40lbs | 18.2kg
Warranty: 3 years parts and labour
[upload=jpg]uploadImages/20041514322558250.jpg[/upload][upload=jpg]uploadImages/20041514324398910.jpg[/upload]
[upload=jpg]uploadImages/20041514335214859.jpg[/upload]
最后编辑leslie
[upload=jpg]uploadImages/20041514235748315.jpg[/upload][upload=jpg]uploadImages/20041514284628437.jpg[/upload]
BC22
MSRP:  2150.00 USD
Power output: 125 watts per channel into 8 ohms
Power requirement: 120 VAC 50/60Hz, 600 W Max; also available for 100, 200 or 240 VAC
Dimensions: (w x h x d): 17.5" x 3.625" x 14.375" | 445 mm x 92 mm x 365 mm
Weight (without packaging): 30 lbs | 13.6 kg
Warranty: 3 year parts and labour [upload=jpg]uploadImages/20041514245294628.jpg[/upload][upload=jpg]uploadImages/2004151425131160.jpg[/upload]
BC26
  MSRP:  4995.00 USD
Power output: 200 watts per channel into 8 ohms, 800 watts per channel into 2 ohms
Power requirement: 120 VAC 50/60 Hz, 1800 watts max; also available for 100, 200, or 240 VAC
Dimensions (w x h x d): 17.5" x 9.125" x 20" | 445 mm x 231 mm x 508mm
Weight (without packaging): 85 lbs | 38.6 kg
最后编辑leslie
呵呵,没见过呢!:)
[upload=jpg]uploadImages/20041514213891776.jpg[/upload][upload=jpg]uploadImages/20041514214463876.jpg[/upload]
The BC24 and BC28 Hybrid Stereo Amplifiers
Based on the hybrid technology developed for the AG8000 Amplifiers, the BC24 and BC28 fill the void that many audiophiles feel was created when we discontinued the now classic BC2 series and BC6. If you are unfamiliar with The BC2/BC6 you can read the archived reviews under Classics in our Product Reviews section.
The BC24 and BC28 represent the next step in hybrid evolution from Blue Circle. The best word to use when comparing the BC24 and BC28 to the old BC2 and BC6 series is "more." In every respect the BC24 and BC28 represent an improvement in both musicality and flexibility. They run cooler, are much easier to situate in most systems and will drive a far greater range of speaker loads than their predecessors.
Did we mention musicality? We took some flack from owners and aspiring owners of BC2/BC6 when we announced that those products would be removed from the line-up. Those who have had the opportunity to listen to the new BC24/BC28 now understand our decision. The differences are not subtle. We could prattle on about about how much better the bass-soundstage-air-etc. is but we can't describe what music sounds like with words on paper or in this case pixels on a screen. We'll leave that to the reviewers. Don't tell anybody but .......we don't think they can describe music with words either
The BC24 and BC28 each use one 6922 tube per channel running in single-ended high bias Class A mode in conjunction with a solid-state high bias Class AB output stage to accommodate difficult speaker loads. In both amplifiers Blue Circle's proprietary design has been employed to ensure that the tubes operate at their most linear performance level.
Unlike many hybrid and tube amplifiers which can cost hundreds or even thousands of dollars to re-tube, the BC24 and BC28 can be re-tubed at very reasonable cost. At current retail prices these amplifiers can be re-tubed for as little as $30.00USD.
Like all Blue Circle products the BC24 and BC28 employ Blue Circle's traditional engraved stainless steel faceplate complimented by a black powder coated chassis, simple elegance with no expensive cosmetic treatments or gimmicks.
    The BC24  MSRP: 2450.00 USD
conservatively rated at 80 watts/channel into 8 ohms.
   The BC28  MSRP: 3995.00 USD
conservatively rated at 120 watts/channel into 8 ohms.
2 pair of output binding posts for easy bi-wiring.
[upload=jpg]uploadImages/20041514223320987.jpg[/upload]
The BC22 and BC26 True Balanced Stereo Power Amplifiers
* March 2003...the BC22 is now the BC22 MKII.  For details click here.
Over the years, Blue Circle Audio has developed a reputation for reference quality handcrafted products. We are proud to introduce our BC22 and BC26 true balanced power amplifiers. These amplifiers represent a significant departure from our original design philosophy. We have always believed, and still do, that single-ended Class A hybrid topologies produce the best sounding amplifiers. But they do have some drawbacks. They cost an awful lot of money, could run very hot and are very heavy. When we first decided to design and bring these amplifiers to market, we were uncertain that we could satisfy the necessary design and cost criteria, while still producing an amplifier that would meet our personal fidelity requirements. They do tend to be rather stringent. After 5 years of research and development, we are very pleased to announce that we have succeeded.
THE TECHNICAL STUFF
The BC22 and the BC26 are pure solid-state DC coupled true balanced design. They produce a very conservative 125 watts and 200 watts per channel into 8 ohms, respectively. Even though this is a departure from Blue Circle traditions, some things have not changed:
These Amplifiers are totally handcrafted with all the attention to detail.
The simplicity of design that Blue Circle is known for has been maintained. As a result of intensive engineering, we were able to limit the number of components in the signal path.
The power supply can best be described as serious overkill. It is built around a custom designed and manufactured toroid power transformer. Filtering is nothing short of massive. As usual this is accomplished by employing multiple networks of small value capacitors. This technique reduces dc resistance, lowers inductance, and therefore improves transient response.
Connecting hardware and signal path wiring is by Cardas®.
HOW DOES IT SOUND?
Traditionally we do not comment extensively on the sound of our components. However, as the BC22 and the BC26 are such a departure from Blue Circle norms, we felt that some discussion was warranted in this case. What we set out to design and produce, was the best solid state balanced power amplifiers in this category. We believe that the biggest strength of these amplifiers are what they don't do, rather than what they do. Confused? Let us explain.
When you set out to produce a new product, it is only natural that you look long and hard at what's already out there. What we found was that most amps in this price range did a number of things quite well, but they invariably had some flaws that were simply intolerable over long listening periods. For solid-state amps, these problems usually manifest in the upper register. This is where the BC22 and the BC26 shines. There is nothing fatiguing about these amps. They are surprisingly smooth without getting euphonic, no aggressiveness or hardness. They have fabulous lower register extension, taut and controlled without bloating. Nasty nonlinearities are eliminated and they are very very quiet. For the money, these amps are surprisingly musical.
The BC22 and the BC26 are one of the finest amplifiers at this level, handcrafted, affordable and musical. We are confident that you will enjoy these amplifiers with most of today's demanding speakers.
有大虾听过吗?
