leslie ,,,,,,,,,,,,,, [复制链接]
查看: 2697|回复: 3
请你帮我查一下ARAGON的2002和8008MKII功放的资料它们大是什么价目。
ARAGON 2002》
規格
2-ch THX Ultra2 Amplifier
響應頻率
20Hz-20KHz+0/-0.1dB
輸出功率
200w/ch into 8ohms
訊號雜訊比
106dB
TIM/DIM失真
0.00%
消耗功率
60w/1000w Maximum
淨重
15kg
尺寸HxWxD
122(mm)x432(mm)x350(mm)
ARAGON 8008 MK ll》
規格
2-ch Dual Mono Amplifier
響應頻率
5Hz-20KHz+0/-0.1dB
輸出功率
200w/ch into 8ohms
訊號雜訊比
110dB
TIM/DIM失真
0.003%
消耗功率
120w/1500w Maximum
淨重
32.2kg
尺寸HxWxD
168(mm)x483(mm)x400(mm)
http://www.allkind.com.tw/kind.php?kindid=11
The Aragon 2002 is a 2-channel amplifier that achieves its high output using the fewest active components possible for a more dynamic, more powerful and more detailed performance. This minimalist design results not only in better sound, but in amplifiers that consistently rate among the most reliable available at any price.
The 2002 features a single power supply design called SmartPower? In this configuration, a channel could provide substantially more than its rated output for short periods of time by getting more energy from the power supply while the other channels aren't demanding as much. SmartPower?enables the amplifier to perform at optimal levels in high-end two-channel audio environments as well as in the most demanding home theater applications. An elegant blue LED perfectly complements the available black or silver finish options. An included dimmer switch allows you to adjust brightness as well as completely turning off the LED lighting.
Specifications: DESIGN: 2-ch THX Ultra2 Amplifier POWER OUTPUT: 200 watts/ch into 8 ohms at less than 0.03% THD;
CALL 1-800-515-7113 FOR SHIPPING CHARGES (20Hz-20kHz - both channels driven) POWER OUTPUT: 300 watts/ch into 4 ohms at less than 0.05% THD FREQUENCY RESPONSE: 20Hz-20kHz +0/-0.1dB 10Hz-100kHz +0/0.5dB SN RATIO: 106dB A-weighted DAMPING FACTOR: 500 (8 ohms - 50Hz) INPUT SENSITIVITY: 100mV-1W / 1.42V-200W INPUT IMPEDANCE: 20k ohms INPUTS: Gold-plated RCA Phono Jacks OUTPUTS: Insulated Speaker Binding Post Terminals POWER CONSUMPTION: 60W @ Idle / 1000W Maximum HEIGHT: 4.8" (12.2cm) WIDTH: 17" (43.2cm) DEPTH: 13.75" (35cm)
ARAG$1,195.00
ARAG$1,195.00
The new 2000 Series THX Ultra-2-Certified amplifiers from Aragon bring powerful, dynamic, high-end performance to the masses at substantially lower pricing. The 2000 Series amplifiers will deliver 200 watts into 8 ohms and 300 watts into 4 ohms for effortless performance from nearly any loudspeaker systems.
DESIGN:
POWER OUPUT 8:
200 watts/ch into 8 ohms at less than 0.03% THD (20Hz-20kHz - both channels driven)
POWER OUTPUT 4:
FREQUENCY RESPONSE:
TIM/DIM DISTORTION:
0.003%
S/N RATIO:
106dB A-weighted
DAMPING FACTOR:
500 (8 ohms - 50Hz)
INPUT SENSITIVITY:
INPUT IMPEDANCE:
20k ohms
INPUTS:
OUTPUTS:
POWER CONSUMPTION:
HEIGHT:
4.8" (12.2cm)
WIDTH:
17" (43.2cm)
DEPTH:
13.75" (35cm)
WEIGHT:
33 lbs. (15kg)
The new Aragon 8008 MKII power amplifier is an absolutely beautiful piece that delivers incredibly reliable high-power output. It offers the powerful, dynamic performance of high-end boutique products at a substantially lower price. While most amplifiers on the market today are overly complex and require rows of integrated circuits (IC) for protection circuitry, control loops and signal buffering, which has a negative impact on sound reproduction. The Aragon 8008 MKII, however, provides the required output utilizing the fewest active components possible for more dynamic, more powerful and more detailed performance.
Specifications: DESIGN: 2-ch Dual Mono Amplifier POWER OUTPUT: 200 watts/ch into 8 ohms at less than 0.015% THD; (5Hz-20kHz - both channels driven) POWER OUTPUT: 400 watts/ch into 4 ohms at less than 0.03% THD FREQUENCY RESPONSE: 5Hz-20kHz +0/-0.1dB 5Hz-100kHz +0/-1.2dB SN RATIO: 110dB A-weighted DAMPING FACTOR: 400 (8 ohms - 50Hz) INPUT SENSITIVITY: 120mV-1W / 1.7V-200W (SE and BAL) INPUT IMPEDANCE: 46k ohms (SE) 70k ohms (BAL) INPUTS: Gold-plated RCA Phono Jacks & XLR Balanced Jacks OUTPUTS: Insulated Speaker Binding Post Terminals (2 sets per channel) POWER CONSUMPTION: 120W @ Idle / 1500W Maximum HEIGHT: 6.63" (16.8cm) WIDTH: 19" (48.3cm) DEPTH: 15.75" (40cm)
ARAG8008MKII$2,449
http://absoluteaudiovideo.com/ar80mkiidual.html
唔该leslie版主。
