请L版帮忙!谢谢! [复制链接]
查看: 3893|回复: 17
请帮忙搜索麦景图MA6850/6900,贵丰2200的数据,我要下手了.
谢谢!我想在大哥来我家之前完成系统,到时可切磋一下.
呵呵...
GRYPHON在放大器设计上颇具心得,除了Sonata Special Edition、Antileon、Antileon Solo重量级前后级放大器外,TABU系列CD、合并式及前后级放大器则是它最平价的机种。近期,贵丰又推出了带合并式型号的Callisto系列,其中2100、2200为两款合并式放大器,它们的外型设计十分前卫,强调线条的棱角与质感,让人耳目一新。
贵丰Callisto 2200是一款相对于2100功率更大的合并式放大器,面板上没有旋钮,各种控制可通过按键或遥控完成。它的前级输入采用了BB公司出品的OP2604运放,音量控制为马达驱动金属带状可变电阻方式的ALPS电位器,功率放大部分由分离元件组成,左右声道完全独立,末级各采用了4对三肯2SA1216/2SC2922功率管。该机在电源部分也十分重料,采用了独立绕组的一只大型变压器,左右声道分别通过金封整流桥整流,各用了12只大型电解电容,容量达50000余微法。同时机脚为二前一后的三角式发烧级设计,后方一脚为锥状,对于声音表现会产生有利的影响。值得一提的是该机的遥控器十分新颖,柱形机体棱角上的圆形按键及前方多角形的支架加上十分精细的工艺,使其如同艺术品一般。
Effekt:
Frekvensomfång:
Input impedance:
AV Input
impedance:
THD+N:
Signal to Noise:
Gain:
Input sensivity:
Input sensivity,
AV-input:
Output voltage:
RMS:
Peak to Peak:
Output
impedance:
Transistorer:
Output stages:
Trafo:
Bandbredd:
Egenskaper:
Färg:
Vikt:
Mått: 2x200 Watt i 8 ohm
2x400 Watt i 4 ohm
2x650 Watt i 2 ohm
20Hz-20kHz + 0,0 /
- 0,2 dB 0,25Hz-250kHz
+ 0 / - 3dB
10K
47K
1 kHz < 0,05%,
20kHz < 0,25%
< -100 dB "A-weighted"
38 dB
700mV
1V
40V
113V
0,028 Ohm
Selected bipolar
Output stages Double push-pull configuration of complementary high-
speed Sanken transis-
tors for each channel
Dual Mono Holmgren
Toroidal transformer
Bandwidth extending
beyond 350kHz
*True Dual Mono
configuration.
*Infrared remote
control.
*Flash memory
upgrades via PC.
*Zero negative
feedback.
*Microprocessor-
controlled passive
volume potentiometer.
*Extensive mechanical
decoupling.
*Minimal internal wiring.
*Ultra-short signal path.
*Non-magnetic, non-
resonant aluminium
cover.
*Military spec. double-
sided printed circuit
boards.
*PCB-mounted sockets
eliminate wiring and
shorten signal path.
*Gold-plated Swiss
Neutric XLR sockets for
one balanced source.
*Exclusive custom Gryphon gold-plated
phono sockets with
Teflon insulation for 4
inputs.
*Fixed-level AV through-
put for uncompromising
integration with sur-
round preamplifier.
*Vacuum Fluorescent
Display with 2 lines and
50 characters.
*Adjustable display
lighting (High, Medium,
Low, Off)
*Optional MM/MC
phonostage module.
*Non-invasive
protection system.
*Designed and built in
Denmark.
Svart
24 kg
175x480x420mm (HxBxD)
最后编辑leslie
麦景图MA6850合并式放大器
MA6850:输出150瓦x2(8/4/2欧姆)功率输出,瞬时峰值输出功率达600瓦(输出变压器设计)。
32000元
    Mclntosh(麦景图)是一个具有传奇色彩的音响品牌,50余年
的风雨,许多名噪一时的音响品牌已经灰飞烟灭,回首半个世纪前
创立的今日硕果尚存的品牌,只有1926年的TANNOY(天朗),1936
年的Quad(国都),1941年的Klipsch(杰士),1949年的Mclntosh
(麦景图)与1953年的Marantz(马兰士)这五家了,但岁月年轮的
转动似乎也使它们越战越坚,黄金品牌在它们身上显现的光环似乎
更显夺目。
   MA6850是麦景图推出时间不长的一款晶体管合并机,它保持着麦
景图一而贯之的外观风格,玻璃面板、左右完全对称的布局、湖水蓝
的功率指示表、黑色包金属边的控制旋钮这些麦景图的固有特色在
MA6800身上也不例外,而每一部分的精工细作都让人叹为观止,精美
得让人舒心。与它同门的另两款合并机MA6450、MA6500相比,MA6850
还带有音量数字显示,直观方便很多。同时本机带有双重开关,第一
级可开启电源,第二级则可开启显示屏及后级输出,此设置可以使机
器长期处于待机状态,需要工作时直接进入最佳状态。
   本机最具特色的应是它采用了超宽频多线并绕输出变压器。这是
麦景图数十年引以自豪的传家之宝,在其胆机与石机上均有应用。这
是将数十支漆包线平行绞合后绕于铁芯的一种方式,结构十分特殊,
麦景图放大器具有一种特别的音色是与它密不可分的,本机所用变压
器则设有2欧、4欧、8欧三组抽头,且采用了超宽频设计,以满足现
代音频的需要。
  本机内部相对于许多HI-END功放而言,十分复杂,简捷至上的HI
-FI准则在此并不通用,从密布接口的背板到面板控制键上的一束束
长长引线、仪表式的布局与其面板上密布的旋钮,包括等响度、高低
音调节、录音输出、左右平衡键都让人惊讶,这不是发烧的作法呀!
但它的声音却十分的好,好得让人佩服,麦景图的确有自己的一套设
计理念。当然MA6850也是重料堆积而成的,中部硕大的电源及输出变
压器,两只竖立的带摩托罗拉金封大功率对管MJ15024、15025的散热
器,后方印有麦景图标识的两只硕大滤波电容将本机内部填充得十分
密实,也使本机重达31公斤。
   输入、输出端子的繁多,增加了MA6850的随和性,可以灵活地对
应各种局面,前级输入与输出方式也为玩家增添了乐趣。而本机的保
护电路十分周全,Power Guard微电脑傍路监察系统可即时对比输入
与输出信号的波形差异及检测扬声器反电动势反馈信号,在不正常的
情况下可迅速降低输入信号,而Sentry Monitor时刻电流监察系统则
可监测功放的电流,在过流状态出现时将会瞬时断开电源,达到保护
机器的目的。另外,对于其负载----扬声器则更有输出变压器的隔直
保护,几乎可保其万无一失。
   如果说麦景图的声音富有很强的个性,这在过往的产品中其表现都
是十分明显的,它常常会让人感到声音过慢、过厚,但追求者却仍然
众多,无疑麦景图声音的魅力更胜一筹。那种音乐的表现方式也的确
是迷人,不然它也不会历经50年不倒,形成了个性的产品、理念真的
不容易被推翻。而近年来麦景图的产品也针对声音表现方面作出了一
些调整,MA6850就是其中一款既保持原有风格,又带有新的声音走向
的机种,从它的声音表现上可感到麦景图的不俗。除了乐感出色外,
它的解析力、控制力、声音的饱满度也都是一流的,声场的再现相当
不错,特别是音乐色彩的变化、细节的再现更是惊人,这可是带有输
出变压器的机种啊,让人不能不感叹,某些固守HI-FI理念的机器,
为何离麦景图MA6850的表现相去甚远?
[upload=jpg]uploadImages/200310229511436796.jpg[/upload]
最后编辑leslie
GRYPHON(贵丰)Callisto 2200合并式放大器
[upload=jpg]uploadImages/200310229573418342.jpg[/upload]
Gryphon callisto 2200 合并机
    虽然我们试听的那部callisto 2200是经过巡回演示的机种,照道理应该早已熟透,但经过一段长时间完全断离电源之后,甫开声仍然显得颇为冰冷生硬,一听便知道是热身不足的毛病,结果要不停直 run 三天声音才回复从容稳定。
    聆听完全进入状态的callisto 2200 绝对是一件赏心乐事,因为它具备Grypbon 分体机种所拥有的那种音色华丽的贵气,(这也是它比TABU 系列明显优胜的地方。)声音幼细与气势兼备,一开声便会令你有一咱出乎意料之外的惊艳感觉。
动人故事
    当然,一分钱一分货,你不能期望callisto 2200拥有 Sonata那种放大镜式的惊人分析力和幼细感,与及 Antileon那种无坚不摧式的威猛迫力,但它却有着不易买得而发烧友又热烈渴求的浓郁音乐感,所以很容易便会把你引领投入音乐境界之中,是五万元级以内,最有音乐感染力的少数机种之一。
    听蔡琴的最新超级宝碟‘机遇’,鲍比达的钢琴不但清晰通透,琴音粒粒清楚,他的演绎更是充满创作的神髓,即与随意之中亦与琴姐的歌声互相配合,最精彩之处乃是鲍比达在为琴姐每一段独白伴奏之前都会先弹奏一段音乐引子,你亦会很自然地被琴音吸引过去,但当琴姐开腔讲话之后,钢琴的声音竟然仿似就此消失掉,其实是与琴姐的说话混成一体,独白竟变成美妙的动人故事。一段你完全被吸引细听的动人故事。到第6首‘月光小夜曲’的中段,假如你是在晚间欣赏(或是像本刊的密封式试音室)而且把灯光熄掉的话,你的四周马上变成偌大一片田园,数不精的蟋蟀在叫,天花竟像开了洞一样,变成漆黑夜空,所差的只是尚欠繁星点点而已。 callisto 2200 完全有能力使我感受到刚才我所叙述的境界——也不是文人多大话,而是监证实录。
神乎奇技
    到试听发烧友都非常熟悉,动态与速度都劲到飞起的结他天碟‘Friday Night In San Francisco ’的SACD 版本,要准确重现音乐会当晚的狂热气氛,Al Dimeola,John Mc Laughlin Paco De Lucia三位当中代结他大师那双神乎奇技的结他魔术手演出,对放大器而言绝对是一个严峻的考验。 callisto 2200 重播起来并没有叫人感到半点儿失望,三支结他以狂风扫落叶的姿态并发出扣人心弦的法林明哥乐曲,3双手, 18条弦线以极高速度按、勾、弹、扫,听起上来也有令人目眩的感觉,但你仍可以清楚听得见每一粒音条款,没有半点拖泥带水。你不但会在聆听乐曲的期间精神崩紧,在一次高潮之后再期待另一个高潮的来临,而且更会跟随录音内的观众一同欢呼,一曲既终之后开口赞叹!重播超过 100KHz频宽和 120Db动态规格的 SACD ?callisto 2200绝对胜任愉快,问题是你的喇叭能否应付得了?
    接近 $43’000售价的 callisto 2200 可以说绝对物有所值,钟情于Grypbon分体机种而又暂时在摆位或预算上未能成事的发烧友应该去听听 callisto 2200的表现,因为你会发觉新一代的名牌合并机原来也会如此可爱。
返回
YOU ARE LATE:)
McIntosh麥景圖有哪些最新型號合併式放大器産品?輸出功率的分別爲何?
答: 1.MA6500:輸出200瓦x2/ 4歐姆功率輸出,瞬時峰值輸出功率達400瓦;
2.MA6900:輸出200瓦x2(8/4/2歐姆)功率輸出,瞬時峰值輸出功率達400瓦(輸出變壓器設計)。
音响精品橱窗
Mclntosh MA6900合并式放大器
AE300系列音箱
DENON AVC-A11SR 7声道高级AV放大器
Meridian DSP6000数字化扬声器系统
JEFF ROWLAND SynergyⅡ前级放大器
MARTIN LOGAN
返回目录
美国老牌Hi-End名厂McIntosh(麦景图)推出了最新合并放大器MA6900,该机的面市具有重大意义,因为它是庆祝该公司成立五十周年的系列产品之一,也是麦景图有史以来输出功率最大的合并式机型。说起麦景图,其永不改变的外形设计已经成为发烧友心目中的经典,像黑色玻璃面板、蓝色指示灯、按键开关等;而另一方面他们也致力于维持声音走向的不变,因此使用输出变压器的技术也永远不变,即使采用晶体管的功放亦如此,其中包含的靓声技术则是麦景图的独家秘技。通过输出变压器,MA6900可接驳阻抗为2Ω、4Ω及8Ω的音箱,在20Hz~20kHz全频带内每声道输出功率高达200W,而在最大输出功率状态下,失真也仅有0.005%而已。在MA6900上保留的麦景图传统功能还有其杰出的5段频率均衡器。自从CD问世之后,由于其输出频响非常平直,所以原来音响系统中常见的多段频率均衡器渐渐被抛弃不用,而麦景图则在自己的功放中保留了这一功能,因为他们认为无论手段如何,获得靓声是最为重要的。MA6900的5段频率均衡器可在30Hz、150Hz、500Hz、1.5kHz及10kHz等5个频率点上进行±12dB的控制,而功放的谐波失真仍然控制在0.005%以内。麦景图还推荐了与MA6900搭配的器材,计有MVP841 DVD/CD/VCD播放机、MR85 AM/FM调谐器、Academy Series LS320书架式音箱及PS112有源超低音等。
    参考价格:55000元
或者CHORD也很好
http://195.40.133.90/website/main-products.htm
行啊!
上次问你要个电话号码也没给我(我的可已经给你),不够朋友哦!
小弟我近期忙着办婚事,待下月中吧,那时我还想见见L版呢.
呵呵!!!
有啊,偶还是老一套。Creek5350se签名版,120W*2
建议先抱着1。3SE去听听看Creek5350se(85W*2的),再下结论。我可以陪你一起去
最后编辑庆庆
恭喜啊:)
