请问达尼Piano Noble [复制链接]
查看: 2222|回复: 9
[upload=jpg]Upload/2004102015573148401.jpg[/upload]
请问DX们,达尼的Piano Noble怎么样?价格大约多少?
Dali Piano Noble
1546 USD
Dali's claim that you don't have to sit bang in the middle to get a natural tonal balance is realised in practice
Cold to the touch and, as the name suggests, shaped rather like grand pianos, Dali's elegant columns use anodised extruded aluminium enclosures and are manufactured in mirror pairs which means you can have the curved side facing inwards or outwards. I chose outwards.
Dali claims the distinctive curvature makes each enclosure immensely rigid and that the heavy, inert layer bonded to the inside suppresses resonance. The baffles are made from MDF though, and support three drive units: a one-inch soft dome tweeter and two five-inch mid-bass drivers. The treated paper cones used in the bigger drivers are said to combine low mass and high rigidity.
Each enclosure is front-ported behind fixed grilles, and with the cable terminal hidden away under the plinth, the appearance is exceptionally clean and sleek, though the plinth's footprint is rather small.
Sound quality
Dali's claim that you don't have to sit bang in the middle to get a natural tonal balance is realised in practice; you quickly forget about the speakers when the music starts, and that's always a good sign.
It's hard to single out facets of the Dali's sound. The balance is relaxed, musical and unobtrusive but far from uninformative. Bass addicts will have to look elsewhere for visceral thrills (or add the matching Forte subwoofer which successfully adds both slam and extension) but the long, tall Dalis are smooth and tuneful at low frequencies and subtle resolvers of detail through the mid and treble. They go loud without strain and always stay impressively in control.
Best of all, their delivery sounds natural and unforced. Not the most dynamic in this test, maybe, but probably the easiest to listen to.
Conclusion Ostensibly designed to fulfil a role as part of Dali's Piano home cinema system, the Nobles do just fine as stereo speakers. They look striking and tasteful but aren't 'in your face'. Much the same can be said of their sound.
名琴系列中最大座地主音箱型号,融合艺术性及高贵音质供宽阔环境中使用。
·双5"低音单元提供良好之延伸度。
                             频率响应 41Hz -24 kHz +/-3 dB
                             分频点 (Hz) 2800 Hz
                             灵敏度 89.5 dB
                             阻抗 (欧姆) 4 Ohm
                             最高输出音压 109 dB
                             建议承受功率 (瓦) 40-160 W
                             高音 1"
                             低音 2X5"
                    (阔x高x深) (公分) 19.2 x 116 x 23.2cm
                            净重 (公斤) 11.3kg
最后编辑leslie
样子很不错
样子象AV箱,够苗条。
蛮贵的,估计就是这个铝合金的箱体贵吧。
哦!大家都不看好。
SMERT 在 2004-10-20 16:10:46 发表的内容
兄是指箱体容量不足吧
箱体小,单元也小。而且看多了只注重内质的音箱,反而觉得这样的样子难看!
哈!样子可以得到肯定。何必去买这样为了外形而妥协的东西。
这喇叭不会好声的
兄是指箱体容量不足吧
