美国人真幸福! [复制链接]
查看: 6213|回复: 29
NB!!300马力!!!!6速手动!!极速250公里! Dodge Caliber SRT-4 Puts Power in Small Package!!
现在的DODGE NEON SRT-4才$2.1万美元. 新CALIBER SRT-4价格估计只要2.3-2.5万美元!  而高速油耗只要百公里8.8个油.
Posted Feb 7, 2006, 8:35 PM by Editor
Category: Chicago Auto Show
Just a month after the Dodge Caliber wowed the auto show crowd in Detroit, a high-performance version of the replacement for the Dodge Neon makes its debut at the Chicago Auto Show--the Dodge Caliber SRT4.
(IMG:http://images.thefirehouse.biz/general/calibersrt.jpg)
SRT4 project team leader John Cathcart discusses just how powerful this souped-up version of the Caliber is and how it got there. Excerpts from his interview are below.
What turns a Dodge Caliber into a Dodge Caliber SRT4?
"The first thing is horsepower. It all starts with the engine. We'll be upping the output to 300 horsepower, 260 footpounds of torque. That's always the prime ingredient of an SRT vehicle. It has to go fast. We of course, balance the approach. It has to go fast, stop fast, turn well, and turn heads. So we take that approach to all areas of the car. We're putting an enhanced braking system on the car as well. We always look for parts we can use from the corporate parts bin. SRT is a small organization. We are investment constrained typically as well as always after offering the best price possible to the consumer as well. The brakes, for example, we took from the Chrysler 300C. We take brakes from a 5,000 pound car and put them on a 3,000 pound car and the car stops real well. We've got performance acceleration, performance braking, now we also want the car to also turn well. So we need to have a little lower suspension. We were able to lower suspension by a half-inch on the car. We will retune the shocks and sway bars as well. But the prime ingredient of the car's handling ability will be the lower CG (center of gravity).
Tires are also very carefully selected for an SRT product. We do have a couple of good tire offerings: an all-season tire and then a higher performance three-season tire. All are capable of the 150 mph top speed of the car.
(IMG:http://images.thefirehouse.biz/general/calibersrtgrille.jpg)
We have an extensive appearance treatment for this car. A new hood, a new fascia. Actually the cut line between the hood and the fascia had to change for the SRT4 in order to package the intercooler. We do bring the body sides down a little bit for better aerodynamics with lower side skirts, and a different rear fascia as well which offers diffuser veins for increased rear down force and better directional stability, better yaw stability in high speeds.
(IMG:http://images.thefirehouse.biz/general/calibersrtrear.jpg)
We think we accomplished all the primary functions of the SRT vehicle with the Caliber SRT4 as well."
How was the World Engine altered?
"The World Engine does offer a pretty good platform for the customization SRT did to the engine. Similar to the Neon SRT4, we start out by turbocharging the engine. We crank up the cylinder pressures, put a turbo on, make sure we're providing a lot of fresh air into the turbocharger inlet, thus we have a reduced restriction inlet system, and then good cold air at pressure to the cylinders via the turbocharger and the intercooler system. That's really the heart of what makes the Caliber SRT4 an SRT from an engine standpoint."
Bigger brakes:
"The brakes are a Bosch system brake, as for the Chrysler 300C. The rotor diameter is 13 and change on the front. The pistons I believe are 58 mm. pistons on the front calipers."
2007 Dodge Caliber SRT-4 Wheel:
Transmission choices:
"The Caliber SRT4 has a unique transmission developed specifically for that vehicle. Six-speed manual is only available in the SRT4 version of the Caliber. The vehicle performance is so tuned around the manual transmission and the gearing and top speed capabilities of that transmission, we really can't offer a different trans in the car and still maintain the level of SRT performance."
2007 Dodge Caliber SRT-4 Rear Wing:
Appearance features:
"Seating is another SRT core element. We have a car capable of high lateral G loadings, stopping, accelerating quick. We need to make sure the driver and front seat passenger are held in place. We have very aggressive thigh and torso bolster and non-slip suede surface area seating. We have a seat that will cradle the occupant, hold them for aggressive driving maneuvers, and also provide a fair level of support at all times. Beyond the seats we do have a unique color scheme for the carpet and the interior trim. It darkens it up a little bit to give it a more performance look. Also, we have an IP that's unique in that we've got a boost gauge that's integrated with the IP. It's not integrated into the dials, it's actually separate were a cubbie bin would be on the left side of the driver. We have added in that spot a uniquely tooled boost gauge so you're able to see what the engine output is or the boost output is.
The seats will have an embroidered logo in the seat back.
Why is the Caliber appropriate for an SRT version?
"The Caliber was a great choice for SRT. It's important to have an entry level vehicle in SRT and maintaining the Caliber's starting price on par with where Neon's was is an important aspect of keeping our brand alive and keeping that end of our brand alive."
Chrysler Group Media (Firehouse)
关键是价格2.5万美元!宝来一破1.8T 150马力百公里加速9秒多还推出一什么运动版,居然要26万人民币!VW真是该死了。
音响采用BOSTON ACCOUSTIC 9喇叭带低音炮!
而且DODGE回不断推出升级包. 以当前的NEON SRT-4看, 装备STAGE2升级包$1500的SRT-4已经与BMW M3加速相同了.CALIBER 如果是AWD的操控将非常不错,如果只是前驱的还不能与M3之类后驱的比. CHRYSLER SRT运动车以德国车BMW M,BENZ AMG,AUDI S一半的价格提供相似性能.
2.4L 发动机是CHRYSLER与现代联合开发的世界发动机,CHRYSLER独自开发自己的可变进气,与双VVT,其效率全面超过日本HONDA,TOYOTA,NISSAN的发动机. 而且此发动机在寿命,噪音震动精细度方面都达到空前水平. 此系列发动机的设计寿命是30万英里=48万公里.远远超过实际一般汽车本身的使用寿命.美国一般私家车到10几年后20万英里的已经很少见了.
过去人们说DODGE NEON SRT-4是CHEAP FAST.
现在DODGE CALIBER就是CHEAP FAST, BUT WELL BUILD ,WELL EQUIPPED各种装备可以说应有尽有!
也只是CHRYSLER能做到这样便宜.GM,FORD两家烂厂是完了.
CALIBER上采用的1.8L I4发动机高达143马力/另有数据说是148马力.是不是所有汽车厂家里的1.8L发动机里最高的.对比TOYOTA的1.8L I4只有130马力.
CHRYSLER的新工厂都是柔性生产线(老厂也进行了同样的改造),每条生产线可以同时生产多个产品,CALIBER,PT CRUISER, JEEP COMPASS,JEEP爱国者4部车基于用以平台将在同一生产线上生产。生产线上不同产品的转换时间只要40秒!
