搞了一对二手的TANNOY SYSTEM1200,哈, $1050美元.贵不贵... [复制链接]
查看: 2693|回复: 4
Sensitivity 95 dB / 1 W @ 1m
Nominal impedance 8 ohm
Frequency response 40Hz - 20kHz
Power Handling (RMS/Programme) 180 W / 350 W
DRIVE UNITS
Driver type 305mm (12") Tannoy Dual ConcentricTM
Dispersion 90 degrees conical
CROSSOVER
Frequency 1.3 kHz
CONSTRUCTION
Enclosure type Optimised bass-reflex loaded
Volume 74 Litres
Dimensions 396 x 649 x 408 (15.59" x 25.55" x 16.06")
Weight 27.0 kg (59.5 lbs)
Finish Spray 'F' vinyl
最后编辑Enki
[upload=jpg]Upload/200542110234193299.jpg[/upload]
全新
$2,495.00
Tannoy System 1200
Reference 12" midfield monitoring system capable of accurate reproduction at very high sound pressure levels for a wide range applications. Designed for use as a midfield monitor or for main monitoring in smaller studios
Main reference monitor. 310mm Dual Concentric unit.
Freq. Response 40Hz - 20kHz
Nominal Impedance 8 ohm
Size (HxWxD) mm 396 x 649 x 408 (15.59" x 25.55" x 16.06")
Inputs Binding Posts/Banana Plugs
TANNOY SYSTEM 1200 - DEMO - Demogerät mit voller Garantie/ leichter Gehäuseschaden - 12" Dual Concentric, 100-300W RMS, 8 Ohm, 129dB Schalldruck, 40Hz - 20kHz, 1,3kHz Trennfrequenz, H=397mm, B=649mm, T=408mm, 27kg. Stückpreis - UVP des Herstellers: 900.00 EUR - Sie sparen: 19%
比原来的SYSTEM 12 丑多了。
可是比原来SYSTEM 12占地小了. 准备用一只做家庭影院的中央音箱. 家庭影院的中央单元非常重要,因为70%的声音是从中央单元发出的.所以大箱对营造HT的气氛很重要.而SYSTEM 1200是而不错的选择.同轴的定位,相位准确的优点,这单元是与老D900上一样,动态反映很凌厉适合于HT. 比竟我不愿意为HT花太多钱, B&W 新的HTMD1 中央单元 8000美元!
如果做为HI-FI的主音箱还需要加一对TANNOY的ST系列高音单元.就很完美了
最后编辑Enki
