丹麦加密的CD机 [复制链接]
查看: 2848|回复: 8
有人听过这款CD机吗?有具体的参数能告诉我一下,或者介绍也可以,就是这款Gamut CD 1 Mk II CD Player
最后编辑舍得
顶级器材不外乎瑞士、德国、美国,其他地区的少考虑
[upload=jpg]Upload/200511101255026573.jpg[/upload][upload=jpg]Upload/200511101261216241.jpg[/upload]
GamuT Audio
The Entire Range of Musical Notes
The GamuT CD1 MkII player is a major improvement in sound quality over our previous DAC, which used the famous Burr Brown 20-bit 1702K DA converter.
GamuT CD1 MkII is like the predecessors CD1, CD1R and CD1S based on a Crystal CS 4390 DA converter with reduced jitter sensitivity. This IC delivers a wonderfully fluid, non-mechanical sounding midrange and treble with an exceptional smooth resolution of fine details. The Crystal CS 4390 enables a theoretical oversampling at 128 times 44,100 Hz. That is 5,644,800 Hz. This is twice the speed of DVD-audio/SACD. Most upsampling only reaches 192 kHz.
All circuit boards and the CD drive are mounted on rubber insulation, so disturbing vibration is reduced.
The drive mechanism control board contains a number of trim potentiometers allowing individual performance adjustment during final testing.
The design matches our GamuT D200 and C2R with engraved text panel in anodized aluminium, and a 10 mm thick aluminium front panel.
Technical data:
Dimensions:            112 x 431 x 408 mm, package weight 12 kgs.
Output signal:          4 Volt
Output impedance:  150 Ohm balanced XLR
Output impedance:  75 Ohm RCA
THD:                       0.002%
1 pair gold-plated RCA sockets
1 pair balanced gold-plated XLR male sockets
BNC socket digital output 75 Ohm
Signal to noise limited by 16bit CD signal to 96dB.
Crystal CS4390 DAC
Shipping weight: 15 kg
Specifications may be subject to changes without prior notice
很强的牌子啊,他的功放跟箱子口碑极好,cd机就不知道了,国内有卖吗?
不知道怎么上图
此款CD机是丹麦的,,听上去还不错的,细节等方面都不错啊,就是不知道质量如何,读碟等工作如何
顶一下,再问
有听过他的吗?感觉如何,和我的贵丰2100加丹拿1.8MK2搭配如何啊,和瑞宝CD机比哪个更好呢
我也听说他家的功放很好的,就是CD机没有听说过,国内有卖啊,广州海印
