B&W 新800系列美元价格!!! [复制链接]
查看: 3906|回复: 10
Model overview and pricing (US $):
800D $20,000 a pair - A 3-way system comprising 2x 250mm (10 in) Rohacell bass drivers, 1x 150mm (6 in) Kevlar FST mid driver and a 1x 25mm (1 in) diamond dome tweeter. Contains several unique refinements, most notably the ultimate in crossover capacitors using silver and gold metals.
801D $16,000 a pair - A 3-way system, comprising 1x 380mm (15 in) Rohacell bass driver, 1x 150mm (6 in) Kevlar FST mid driver and 1x 25mm 1 in) diamond dome tweeter.
802D $12,000 a pair - A 3-way system, it comprises 2x 200mm (8 in) Rohacell bass drivers, 1x 150mm (6 in) Kevlar FST mid driver and 1x 25mm (1 in) diamond dome tweeter.
803D $8,000 a pair - The 803D is a completely new speaker introduced as result of market feedback with the aim of providing something of the performance levels of the flagship 800 models but using a more conventional looking cabinet. Of slightly larger dimensions than the 803S, the 803D is a 3-way system comprising 3x 180mm (7 in) Rohacell bass drivers, 1x 150mm (6 in) Kevlar FST mid driver and 1x 25mm (1 in) diamond dome tweeter.
803S $5,500 a pair - A 3-way system comprising 2x 180mm (7 in) Rohacell bass drivers, 1x 150mm (6 in) Kevlar FST mid driver and 1x 25mm (1 in) alloy dome tweeter. The 803S’s cabinet, and internal Matrix, have been revised to increase stiffness, which has resulted in an increase in weight of 11kg (25 lb) over the previous 803 model.
804S $4,000 a pair – The entry-level 3-way model in the 800 Series and comprises 2x 165mm (6.5 in) Rohacell bass drivers, 1x 150mm (6 in) Kevlar FST mid driver and 1x 25mm (1 in) alloy dome tweeter.
805S $2,500 a pair - Builds on the huge success of the Signature 805, offering greatly improved performance from the same cabinet design. It is a 2-way system comprising 1x 165mm (6.5 in) Kevlar bass/midrange driver and 1x 25mm (1 in) alloy dome tweeter,
SCMS $2,200 a pair - Based on the 805S and designed to offer 800 Series performance from an on-wall location. It comprises 1x 165mm (6.5 in) Kevlar bass/midrange driver and 1x 25mm (1 in) baffle-mounted alloy dome tweeter.
DS8 $3,000 a pair - A new rear channel speaker designed for both dipole or monopole operation, selectable via a 12V trigger or mechanical switch. It comprises 1x 165mm (6.5 in) Kevlar bass/midrange driver, 2x 100mm (4 in) Kevlar midrange drivers and 3x 25mm (1 in) alloy dome tweeters.
HTM1D $8,000 each - The new flagship centre channel of the 800 Series. Referred to internally as the ‘Hummer’, it, for the first time, offers the Marlan head unit of the flagship 800 models in a centre channel. It comprises 3x 200mm (8 in) Rohacell bass drivers, 1x 150mm (6 in) Kevlar FST driver and 1x 25mm (1 in) diamond dome tweeter.
HTM2D $4,000 each - A new model offering the diamond tweeter in a more conventional cabinet. It comprises 2x 180mm (7 in) Rohacell bass drivers, 1x 150mm (6 in) Kevlar FST driver and 1x 25mm (1 in) diamond dome tweeter.
HTM3S $2,500 each – Similar to outgoing Nautilus HMT1 and comprises 2x 165mm (6.5 in) Rohacell bass drivers, 1x 150mm (6 in) Kevlar FST driver and 1x 25mm (1 in) alloy dome tweeter.
HTM4S $1,300 each - Builds on the outgoing Nautilus HTM2 and is near identical acoustically to the 805S. It comprises 1x 165mm (6.5 in) Kevlar mid/bass driver and 1x 25mm (1 in) alloy dome tweeter.
ASW875 $4,000 each - (1x 380mm / 15 in) Rohacell bass driver, coupled to a 1000w power amplifier and B&W’s digital room correction system.
ASW865 $3,200 each - (1x 300mm / 12 in) Rohacell bass driver, coupled to a 1000w power amplifier and B&W’s digital room correction system.
ASW825 $2,500 each - Identical to the outgoing ASW800, except for the upgrade of a 300mm (12 in) Rohacell cone driver.
805S与704差不多价格,绝对704强多了.
ENKI 在 2005-3-8 20:58:13 发表的内容
新805相当吸引人! $2万RMB左右,原来的签名版805要3万!
签名版嘛!
设计的目标可能不同.
新805S,S就是签名板的意思.
Good price !!!!!!!!!!
804S $4,000  国内实际成交要多少?哪位DX知道,想上它。。。
又是签名版, 看看先! 奇怪.....上纲看看.
价格和国内差不多。
