woodylee请进,关于22L音箱木皮 [复制链接]
查看: 3346|回复: 13
你原来说QUAD22L表皮是印刷的,请你看看下面这段文字,
来自:http://www.hifibitz.co.uk/product.asp?id=194
Quad 22L Floorstanding Speakers
In true Quad tradition, the L-series dynamic loudspeakers offer levels of detail, neutrality and stereo imaging beyond anything else in their category. Following in the footsteps of their famous ESL brethren, all L-series models set new standards of performance at their prices. A wide frequency response and incredibly accurate drivers produce a sound-stage so vivid and coherent you can visualise each and every sound in three dimensional space. Build-quality is, as you would expect, superb. Each cabinet is made from reinforced 18mm MDF, with a choice of four real wood veneers. Each cabinet then has seven coats of piano lacquer applied, with each coat drying for a full 24 hours before being cut and polished ready for the next coat. High quality gold-plated bi-wire terminals and oxygen free internal wiring ensure excellent signal transmission.
·  Bass: 6.5 inch, 170mm KEVLAR
·  Mid: 6.5 inch, 170mm KEVLAR
·  Tweeter: 25mm Textile dome
·  Recommended Maximum Amplifier power per channel: 300w
·  Nominal Impedance: 6ohm (suitable for use with 8ohm amplifiers)
·  Sensitivity: (1w @ 1m) 89dB
·  Frequency Response: 30Hz-24kHz
·  H.F. response limit: 43kHz
·  X-over point: 150Hz, 3kHz
·  Frequency Fb: 35Hz
·  Height: 850mm + 15mm plinth
·  Width: 205mm
·  Depth: 278mm
PULSAR兄,你看你自己的QUAD 22L 是真皮的吗?
我认为只是印刷精良而已......ATC的纪念版倒是真的树根帖皮......
是吗?何以见得?
说的是老款的
新的是真木皮的上面也写得很清楚:with a choice of four real wood veneers(真木薄木皮). Each cabinet then has seven coats of piano lacquer applied, with each coat drying for a full 24 hours before being cut and polished ready for the next coat.
不知道哪段文字有说到QUAD是贴木皮的,但有点常识的人都会看得出真木皮和印出来的木皮的区别在哪,建议去音箱店看看吧
PULSAR 在 2005-4-14 0:38:04 发表的内容
我就是看到这段话才证实是真木皮的。才发这帖子。
你又说这段话是指旧款,你的意思就是说旧款是真木皮,新款是假的。
郁闷。
DING
我也是22L的用家,我的是红色的,
两个音箱的木纹不一样.
最后编辑cdc
PULSAR 在 2005-4-13 23:58:22 发表的内容
说的是老款的
PULSAR兄,你说老款是假木皮吗?
woodylee 在 2005-4-14 10:42:37 发表的内容
是真木皮的,真木皮是没有完全一样的纹路的,印不出来的
